Vidéos voiles
10 years 1 month ago #177082 by La Marmotte
Replied by La Marmotte on topic Vidéos voiles
La double dérive aide forcement indirectement au vol: tenu de cap gite et en rigidité
10 years 1 month ago #177083 by Fripouille
Replied by Fripouille on topic Vidéos voiles
mmh en gite je vois pas trop comment! En cap, si je ne dis pas de bêtises, un profil simple avec le même profil et avec deux fois plus de corde ne devrait pas être moins performant. En rigidité oui ça apporte mais vu le moment de redressement du cherub, je ne pense pas que les efforts soient si importants que cela. Apparemment c'est tout le foil qui bouge!
En tous cas ça marche bien et c'est joli à voir!
C'est une photo de sailing anarchy
Avec l'explication:
Our solution is a twin centreboard Pi foil configuration with a large main foil.
I was going to make the foil with a 1.6m span but have reduced it to 1.45m so that it still loads onto the trailer and so that we can roll it for rigging with the foil retracted against the hull. The foil area is 0.22m^2, giving 30% more area to weight than the more recent moth foils. This gives a 10:1 AR similar to the Blade Rider or first Mk2 foil but lower than the more recent ones.
The Pi foil configuration allows the wand to control the pitch of the entire foil which should give better height control than just the flap.
It also allows a centreline wand to be used.
It is was much easier to build as there are no structural T joints or complex flap assemblies.
We have used a DAE41 foil section that was developed for low Reynolds human powered flight.
It has low Cd for Cl near zero to Cl ~1.5 which is higher than we would ever want to use because at that level the induced drag would be higher than the hull drag if we were low riding. The section has quite a high pitch moment. To counter this we have added a tail plane to the foil.
i14 - Le gueux.
The following user(s) said Thank You: Adrian, Yoann J, Alexandre 38
10 years 1 month ago - 10 years 1 month ago #177085 by La Marmotte
Pour la gite j'aurais tendance à penser que le flux canaliser dans le "tunnel" stabilise forcément le bateau, mais peut etre que je dis une grosse bêtise ???
Quel beau projet !
Last edit: 10 years 1 month ago by La Marmotte.
10 years 1 month ago #177386 by Cédric F
Replied by Cédric F on topic Vidéos voiles
Belle vidéo pour le Bart Bash aux Bermudes avec les hommages de ceux qui ont bien connu ce coureur dont le souvenir est encore très fort dans le monde anglo-saxon de la voile de compétition.
10 years 3 weeks ago #177849 by Cédric F
Pas mal ! Les rares images des Français, c'est quand ils font le pitre sur les échelles du RS800. N'est-ce pas Mathéo ? :P
10 years 3 weeks ago #177864 by La Marmotte
Choix de musique un peu soap opera mais sinon top !
10 years 3 weeks ago #177876 by LarDon
Replied by LarDon on topic Vidéos voiles
Il s'appelle Matéo, et ce n'est pas lui sur la vidéo, c'est Axel. Tu aurais du t'en douter, sauf si tu confonds Eulalie et Yann... ;-)
9 years 11 months ago #179297 by Cédric F
Ca vaut ce que cela vaut mais 23 minutes d'actualité voile, c'est toujours bon à prendre.
9 years 11 months ago - 9 years 11 months ago #179300 by Alexandre 38
Replied by Alexandre 38 on topic Vidéos voiles
Quand est-ce que BSP sacre le BreizhSkiff Sailor of the Year ? :sick:
Last edit: 9 years 11 months ago by Alexandre 38.
9 years 11 months ago #179304 by LarDon
Ptit teaser de la nav raid de samedi entre carnac et Séné : 2 RS200 et 1 RS Aero avec les jeunes de Carnac.
15-23 nds d'Ouest tournant Sud. Vent contre courant dans l'entrée du golfe. Impressive and fun!
9 years 11 months ago #179308 by LarDon
De bien bon souvenirs!
Vraiment quelle régalade le RS200 sous spi dans 15nds+!
On en a profité pour faire barrer les moins habitués, on a fait des manoeuvres, et on a tâté les vagues et les talus à l'entrée du golfe. Flippant
GPS max speed 14 nds. Des sensations bien supérieures tout en restant safe.
The following user(s) said Thank You: Adrian, Philippe G
9 years 10 months ago #179476 by Cédric F
livestream.com/accounts/2580174/events/6682026
Les finales de la Star Sailors League. De la voile diffusée en live avec du pognon pour attirer les stars de la régate... Une organisation parfaite. Par contre comment dire... le Star pour ce genre de régate qui a vocation a être diffusée...
9 years 10 months ago #179672 by Cédric F
Bon ok c'est une vidéo promo mais de bien belles images tout de même !
The following user(s) said Thank You: LarDon, ggc
9 years 10 months ago #179717 by Cédric F
Elles resteront à jamais comme les premières championnes olympiques de skiff féminin. Elles sont intelligentes, charmantes et accessibles. De vraies icônes pour notre sport !
The following user(s) said Thank You: ggc, Manu, Alexandre 38, NicodeLyon
9 years 9 months ago #179978 by Cédric F
  • Fréd
  • Away
  • User
  • User
9 years 9 months ago #179981 by Fréd
Replied by Fréd on topic Vidéos voiles
Cédric F wrote: vimeo.com/197833561
:P
"There are a few issues with boat setup that are yet to be sorted out..."
Dites-moi si je me trompe, mais j'appelle ça "un test peu concluant" ! :whistle:
9 years 9 months ago #179982 by ggc
Replied by ggc on topic Vidéos voiles
:P
Lâche toi c'est une merde :whistle:
9 years 9 months ago #180003 by Cédric F
Merci Sailing Annarchy pour avoir dégoté cette vidéo des Cherub Australiens.
The following user(s) said Thank You: lolo, loloma, pj47000, Alexandre 38, NicodeLyon
9 years 9 months ago #180005 by lolo
Replied by lolo on topic Vidéos voiles
Comme série jeune, c'est....différent du 420 :P
J'adore la situation "qui aurait pu mal finir mais qui finit pas si mal" à 1m30 :woohoo:
9 years 9 months ago #180009 by thierrylll
Replied by thierrylll on topic Vidéos voiles
je croyais que le cherub était un double trap
