a vendre RS600 1500 euros
13 years 5 months ago - 12 years 3 months ago #145977 by cadre
Last edit: 12 years 3 months ago by cadre.
13 years 5 months ago #146016 by guytoon
Depuis quand as tu un RS 600 ?
13 years 5 months ago #146017 by azerty
si j'avais le temps et de quoi stocker, je lui greerait bien mon kit foiler 600FF :_( ;)
13 years 5 months ago - 12 years 3 months ago #146018 by cadre
Replied by cadre on topic Re: a vendre RS600 1500 euros
13 years 5 months ago #146045 by ERIC C
Les échelles sont elles étroites ou larges, et correspondent à quel poids de barreur?
Merci.
Rs600
13 years 5 months ago - 13 years 5 months ago #146046 by pj47000
D’après les photos c'est des échelles étroites.
Pour le poids du skipper c'est donc d’après les règles de classe à partir de 70Kg :
. WEIGHT COMPENSATION
3.1 There are two wing sets of differing widths that may be fitted to the RS600:-
Wing set “A” giving a total beam of 1931mm
Wing set “B” giving a total beam of 2133mm
The wing set fitted to a hull shall be matched to the Category Helm Weight (CHW) of
the helmsman as follows:-
3.1.1 CHW less than 70kg Wing set “B”
3.1.2 CHW between 70kg-76kg Wing set “A” without compensating weight, OR
Wing set “B” when a compensating additional weight of 3kg is fitted as proscribed in
rule 3.2.
3.1.3 CHW above 76kg Wing set “A”
3.2 The 3kg weight shall be securely fastened to the hull between the daggerboard casing
and the main bulkhead, and be distributed equally about the centerline
3.3 The wing set and weight used by a helmsman shall be registered with the Class
Association
3.4 A helmsman may change his registered wing set only once in a calendar year
Last edit: 13 years 5 months ago by pj47000.
The following user(s) said Thank You: ERIC C
13 years 5 months ago - 12 years 3 months ago #146050 by cadre
13 years 5 months ago #146051 by Manu
Replied by Manu on topic Re: a vendre RS600 1500 euros
Les échelles étroites permettent de sortir assez facilement et sont plus simples au ressalage. thumbsup;
4000 FRA4711
13 years 5 months ago #146061 by flebas
Ça se discute, avec les échelles larges on peut passer à l'intérieur de l'échelle.
13 years 5 months ago #146062 by PHYLOU
flebas wrote: Ça se discute, avec les échelles larges on peut passer à l'intérieur de l'échelle.
Et dans ce cas c'est beaucoup plus rapide pour le dessalage ;evil;
13 years 5 months ago #146066 by flebas
Aussi ! On peut dessaler sans se mouiller.
13 years 5 months ago #146068 by pj47000
flebas wrote: Aussi ! On peut dessaler sans se mouiller.
Avec les étroites aussi ;)
13 years 5 months ago #146069 by ggc
Replied by ggc on topic Re: a vendre RS600 1500 euros
Plutôt que parler technique, ne pouvez-vous pas trouver un acheteur à ce prix ridicule, quand on voit les annonces ici et là (2500€ en moyenne).
Je connais ce bateau, il est garé à côté du mien et il est nickel. Par contre ça m'ennuie d'en acheter un 3ème thumbsup;
13 years 5 months ago #146071 by Ludovic Collin
Je dirai même plus : On peut se mouiller sans dessaler...
Alain quelle est le modèle du mât ?
Ralingue collée ou intégrée dans le profil ?
À ce prix avec 2 voiles... 8)
13 years 5 months ago #146072 by azerty
Mat Superspar (à vue de nez, de l'etiquette jaune+rouge)
13 years 5 months ago - 12 years 3 months ago #146073 by cadre
13 years 5 months ago - 13 years 5 months ago #146074 by pj47000
ggc wrote: Plutôt que parler technique, ne pouvez-vous pas trouver un acheteur à ce prix ridicule, quand on voit les annonces ici et là (2500€ en moyenne).
J'avais vu ce bateau et j avais préfère mettre plus pour acquérir le 834 vraiment nickel. Le bateau trouvera sûrement acquéreur à ce prix la mais si on veu un bateau nickel il y a un peu de boulot ( à moins que les travaux aient été fait entre temps?)
13 years 5 months ago #146076 by Manu
+1
donc ralingue rapportée en alu
à l'inverse du mât Angel qui a un ralingue dans la forme (mais un manchon en alu)
(enfin si ma mémoire ne me joue pas un vilain tour)
4000 FRA4711
13 years 5 months ago #146077 by Baptiste
GG tu vas pouvoir monter ton club de skiff ;D
13 years 5 months ago #146278 by jeffo1973
Je trouve de nouveau le temps de venir sur le forum, je suis de toulouse et j'aimerai avoir un bateau pas trop cher a la Ganguise, donc je me dis pourquoi pas celui la. Seulement mon expérience est une semaine aux Glenan ! Donc la question RS600 c'est pas un peu trop compliqué ou sportif pour débuter?
