retrécissemnt de la GV
22 years 7 months ago #21780 by administrator
La nouvelle GV HYDE de mon 4000 mesure 17,5 cm de plus au guindant et 11.5 cm de bordure en plus.
Nicolas Honor m'a le jour même rassuré avec un mot de la voilerie HYDE ci-joint!
bruno,
pour info la réponse de Hyde. Merci Nico
Nico
This is the answer from Hydes.
Nico,
I guess from the comment below that the customer is complaining because his new sail is bigger?
This is true of virtually all sails but is magnified on film sails.
Primarily the bolt rope shrinks over time , appearing to make the sail smaller . Also as the Mylar film gets creased over time it also shrinks. This effect is well known to yacht sailors who wait till their sails have been used before submitting them for measurement . This normally gains them rating points on IRM and IMS.
There is no way around this problem and I guarantee if your customers go to other sail makers and use old sails as the pattern they will have extremely small sails especially as they get older.
We make sails on average for dingy size, 2 – 4 inches longer in the luff than the measured mast length and after a season they will only just fit without being loaded to get the tack down to the boom. Also if sails are not over length in the luff a tack crease forms in light air (its like sailing with the Cunningham pulled on when its not needed).
Hope this is of help
mike
;) :D ;D
22 years 7 months ago #21782 by Julien A.
Ca confirme ce que je te t'avais dit par tel. ;)
Alors ce bateau avec un mat et une GV neufs, ca change la vie, non ? :D :D
22 years 7 months ago #21783 by guytoon
Replied by guytoon on topic Re:retrécissemnt de la GV
Et fait attention à ne pas te prendre les pieds dans ta voile ;D ;D ;D ;D ;D
22 years 7 months ago #21788 by Cédric F
C'est vrai que quand on reçoit la nouvelle voile ca surprend parce que c'est vraiment très visible ! Et c'est là qu'on se dit que ce serait super de changer de voile régulièrement.
Plus précisément sur mon premier 4000 1996, j'ai fait deux saisons à fond avec la GV d'origine et en 1998, j'ai racheté une GV neuve uniquement pour la régate. Mais c'est surtout au bout de trois-quatre ans que j'ai vu la différence entre les deux GV... Et comme sur mon dernier 4000, j'ai gardé la GV d'origine du premier bateau, pour l'entrainement, la différence entre ma voile neuve et cette voile d'origine qui a donc 8 ans maintenant est énorme, renforcée aussi par la couleur du mylar qui a changé avec le temps. Bref il faudrait maintenant que je balance une bonne fois pour toute ma GV d'entrainement mais c'est cher une GV neuve ! Par contre c'est quand même bien agréable... Tu vas voir Bruno, la différence surtout associé à un nouveau mât est surprenante.
22 years 7 months ago #21789 by Julien A.
Vu le prix de la GV, je préfère utiliser le plus possible celle d'entrainement et le moins possible celle de régate....
Heureusement qu'elle vieillit bien et qu'on a pas besoin de la changer tous les ans ! :P
22 years 7 months ago #21790 by pchanez
Replied by pchanez on topic Re:retrécissemnt de la GV
cela explique pourquoi cetains equipages deroulent un nouveau jeu a chaque regatte dans les classe a forte monotypie ::) ...
Au fait il y a un nombre limite de voiles par annee en 4000 ?
22 years 7 months ago #21792 by Julien A.
Je n'ai rien lu à ce sujet dans les règles de classe...
A confirmer tout de même.
